KB89530
Published: May 25, 2021
Can't set color or text for On/Off text fields when data source is bit
groov View running on:
  • GROOV-AT1, GROOV-AT1-SNAP
  • GRV-EPIC-PR1
GRV-EPIC-PR1: 3.1.0
All other products: R4.3a
GRV-EPIC-PR1: 3.2.0
All other products: R4.3b
If you set a bit of an integer tag as the source for a Value or LED gadget, groov View doesn't allow you to set the text (for Value gadget) or color (for LED gadget) for the appropriate On and Off fields.
Do the following in the gadget's Properties Panel:
  1. Set the gadget's Data Source tag to a boolean tag.
  2. Change the On text field and Off text field to your desired text (for Value gadget) or color (for LED gadget).
  3. Set the gadget's Data Source tag back to your desired integer tag and specify the desired bit index.
The gadget will display wrong in Build mode, but render correctly in View mode.
