KB89551
Published: February 18, 2025
"Definition Unknown" or Other Errors When Host/Listener Port is 22002
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
Firmware for the following SNAP PACs:
  • SNAP-PAC-S1
  • SNAP-PAC-S1-FM
  • SNAP-PAC-S1-W
  • SNAP-PAC-S2
  • SNAP-PAC-S2-W
  • SNAP-PAC-R1
  • SNAP-PAC-R1-FM
  • SNAP-PAC-R1-W
  • SNAP-PAC-R1-B
  • SNAP-PAC-R2
  • SNAP-PAC-R2-FM
  • SNAP-PAC-R2-W
Firmware for SoftPAC
For groov EPICs: All versions prior to 3.2.0
For SNAP PACs: All versions prior to R10.5g
For SoftPAC: All versions prior to R10.5g
For groov EPICs: 3.2.0
For SNAP PACs: R10.5g
For SoftPAC: R10.5g
If your PAC Control strategy requests communication through port 22002, you may observe a "Definition Unknown" error or other strange behavior. The following is a partial list of ways a PAC Control strategy may request communication through port 22002:
  • Using the Start Alternate Host Task command and specifying "tcp:22002" as the connection string.
  • Using the Listen for Incoming Communication command and specifying 22002 as the port number in the communication handle.
For groov EPICs: Prior to version 3.2.0, it may have been possible to use the Opto 22 reserved port 22002 for your application's communication needs. Beginning with firmware version 3.2.0, the groov EPIC firmware will prevent any use of port 22002.
For SNAP PACs: Prior to R10.5g, it may have been possible to use the Opto 22 reserved port 22002 for your strategy's communication needs. Beginning with firmware R10.5g, the SNAP PAC firmware will prevent any use of port 22002.
You may need to update your strategies to use a different port for communication.
The Workaround section of KB87577 provides information for identifying unused port numbers. You may want to use this guidance to identify an unused port number to replace any usage of port 22002 in your strategies.
If you attempt to continue using port 22002, you will see error message -10 (Bad Port Number) in the message queue.
