KB89575
Published: May 23, 2023
PID Setpoint field turns orange while in range
- PAC Control Basic
- PAC Control Professional
R10.3d to R10.5a (may affect earlier versions)
R10.5b
If your PAC Control strategy uses the Set PID Input High Range or Set PID Input Low Range commands to expand the default/original range of the PID loop, when you run the strategy in Debug mode and view the PID loop in the View PID Loop dialog, the Setpoint may turn orange (indicating out-of-range), even though the Setpoint is within the newly expanded range.
Configure the default range to the widest range expected so that when you change the range using PAC Control logic, it will still be within the default range.
