KB89613
Published: November 2, 2021
Available disk space decreases significantly after a failed system restore
Firmware for the following groov EPICs:
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
Firmware for the following groov RIOs:
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
groov EPICs: All versions prior to 3.3.0
groov RIOs: All versions
groov EPICs: 3.3.0
If you perform a restore (from the groov Manage Home page, click Maintenance > Restore) and it fails, temporary files may not be cleaned up, increasing the amount of used disk space.
There are a few ways you can clear these files:
  • If there is enough disk space available, perform a firmware upgrade.
  • If you have physical access to your device, perform a Restore to defaults.
  • If you have shell access to your device, log in and go to /home/manage22 directory. Remove directories with names starting with restore- and upload-.
  • Contact Opto 22 and request that an Opto Support Engineer access the system using an OptoSupport RSS session to remove the files via shell.
