KB89670
Published: June 15, 2021
TCP connection attempts may fail
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
For listed groov EPICs: All versions prior to 3.2.1
For listed groov RIOs: All versions
For listed groov EPICs: 3.2.1
When host software attempts to open an OptoMMP (TCP) or Modbus/TCP connection, the connection may be refused if previous connections were not closed correctly.
