KB89781
Published: August 17, 2021
Gadgets using computed tags may show an error when groov View starts
- GRV-EPIC-PR1, GRV-EPIC-PR2
- GROOV-AT1, GROOV-AT1-SNAP
GRV-EPIC-PR1, GRV-EPIC-PR2: 3.2.0 to 3.2.1
All other products: groov View 4.3a to 4.3c
GRV-EPIC-PR1, GRV-EPIC-PR2: 3.2.2
All other products: groov View 4.3d
If your project contains any trend gadgets that use computed tags as a data source, when groov View starts, all gadgets using a computed tag may show an error icon, with the error message java.lang.NullPointerException. The groov View log does not contain accompanying errors.
Restarting groov View or the groov device running groov View may clear the error.
