KB89807
Published: September 8, 2021
Creating new strategy allows existing strategy to be overwritten without warning
- PAC Control Basic
- PAC Control Professional
All versions prior to R10.4a
R10.4a
With the following steps, a new strategy will erase the contents of an existing strategy without any warning:
- Create a new strategy (File > New strategy) in PAC Control.
- In the Create New Strategy dialog, select an existing PAC Control strategy.
- Click Open. PAC Control creates a new blank strategy, effectively deleting the contents of the existing strategy.
Do either of these tasks to ensure you don't lose an existing strategy:
- Create a new folder for the new strategy.
- To make it possible to recover from overwriting an existing strategy, configure each strategy to do an automatic archive of the strategy. In PAC Control Config mode, go to File > Strategy Options. In the Archive tab, make sure that there is a check on at least one of the archive strategy options.
