KB89847
Published: August 17, 2021
Unstable connection to MQTT broker using CA-signed or self-signed root certificate
  • ​GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
groov EPIC: 3.1.0 to 3.2.1
groov RIO: 3.1.0 to current
groov EPIC: 3.2.2
After you complete the following steps, the MQTT client connection to the broker might be unstable (connecting and disconnecting erratically):
  1. (Optional) You create a self-signed MQTT client certificate and private key file. Then, you upload the public certificate using groov Manage..
  2. You correctly configure the broker to use SSL and select either:
    • the self-signed MQTT client certificate and private key file you created in step 1, or
    • a root CA-signed client certificate and private key file.
