KB89849
Published: August 17, 2021
Cannot connect to MQTT broker using root CA-signed or self-signed certificate
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
groov EPIC: 3.1.0 to 3.2.1
groov RIO: 3.1.0 to current
groov EPIC: 3.2.2
After you complete the following steps, the groov Manage MQTT client might not connect to the broker:
  1. (Optional) You create a self-signed MQTT client certificate and private key file; the private key file is in a PKCS format other than PKCS#1. Then, you upload the certificate and private key file into groov Manage.
  2. You correctly configure the broker to use SSL and select either:
    • the self-signed MQTT client certificate and private key file you created in step 1, or
    • a root CA-signed client certificate and private key file.
The cause of the problem is that the private key file (either the root CA-signed or the self-signed) is in a PKCS format other than PKCS#1; groov EPIC and groov RIO currently only support private key files in PKCS#1 format. You can convert the private key file into PKCS#1 and then upload the converted private key file into the groov EPIC or groov RIO. The following instructions assume you are familiar with and work with the OpenSSL software library:​
  1. Run the following OpenSSL command: openssl rsa -check -in client-key.pem, where client-key is the name of the private key file.
  2. Copy the output text and paste into a text file, then save it. The text file is now in PKCS#1 format.
  3. Upload the text file into groov EPIC or groov RIO:
    1. Login to your groov EPIC or groov RIO with a system administrator account.
    2. Click MQTT > Client Authentication.
    3. In the Keys section, click Add/Update.
    4. Navigate to the folder where you stored the text file you created in step 2.
    5. Select the text file, then click Open. groov Manage installs the key file.
  4. Restart the groov Manage MQTT client:
    1. In the Client Authentication page, click Back.
    2. In the MQTT Status section, click Disable. Wait a few moments for the MQTT  Status to show Disabled.
    3. Click Enable.
