KB89913
Published: March 2, 2026
Message does not clearly explain restricted I/O channel combinations on universal I/O modules
- GRV-EPIC-PR1
- GRV-EPIC-PR2
Firmware for
groov RIO module GRV-R7-MM2001-10
All versions prior to 4.1.0
4.1.0
For the following modules, if you try to configure a mix of digital outputs and thermocouples in channels 0 through 3, groov Manage should display a message to explain that the mix is not supported:
- groov RIO: GRV-R7-MM2001-10
- groov I/O: GRV-MM1001-10
However,
groov Manage displays the following generic message:
Incompatible Channel Type - The channel type could not be configured. The module's firmware may need to be updated, or the module may have been removed from the chasis.
