KB89962
Published: February 3, 2022
In Edit Analog Point window, scaling fields become unconfigurable after selecting a non-scalable channel type
  • PAC Control Professional
  • PAC Control Basic
R10.4a
R10.4b
In PAC Control configuration mode, when you configure a groov analog I/O channel in the Edit Analog Point window, the fields in the Scaling section become unconfigurable for all channel types if you select a non-scalable channel type. The Scaling section remains unconfigurable (greyed-out) until you close and reopen the Edit Analog Point window.
Manually update the scaling values for the channel in the Edit Analog Point window, then close and reopen the Edit Analog Point window.
