KB89969
Published: February 1, 2022
The “Subtype / Feature” column may not update correctly when moving groov digital I/O channel to another module
- PAC Control Professional
- PAC Control Basic
R10.4a
R10.4b
In PAC Control Configuration mode, the Subtype / Feature column of the Configure I/O Modules and Points window may not display the correct values for channel type and feature after a groov digital I/O channel is moved from one groov digital I/O module to another groov digital I/O module. (However, the channel type and feature are displayed correctly in the Edit Digital Point window.)
For a moved groov digital I/O channel with the incorrect values shown in the Subtype/Feature column, double-click the channel to open the Edit Digital Point window, then select OK. PAC Control updates the Subtype/Feature column in the Configure I/O Modules and Points window for that channel.
