KB89997
Published: June 11, 2025
Nslookup with groov RIO hostname or localhost fails
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM3
3.2.2 to 3.6.1
4.0.0
On a groov RIO, if you run the nslookup command from either groov Manage or through a shell command, you will see an error similar to the following:
Server:         192.168.0.1
Address:        192.168.0.1:53
** server can't find opto-04-87-b4: SERVFAIL
