KB90083
Published: July 6, 2022
groov RIO: 0-400k ohm channel type may report quality code 6 for zero ohm input
Firmware for the following:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
All versions prior to 3.4.0
3.4.0
Under the following circumstances, the channel value on a GRV-R7-MM1001-10 or GRV-R7-MM2001-10 module may return NaN and report a quality code of 6:
- The channel is configured for analog input with a channel type of 0-400k Ohms.
- The input is at or near zero ohms.
