KB90085
Published: December 16, 2021
Log4j vulnerability in groov View may allow remote code execution
- GRV-EPIC-PR1, GRV-EPIC-PR2
- GROOV-AT1, GROOV-AT1-SNAP
GRV-EPIC-PR1, GRV-EPIC-PR2: All versions prior to 3.3.2
All other products: All versions prior to 4.3g
GRV-EPIC-PR1, GRV-EPIC-PR2: 3.3.2
All other products: 4.3g
A vulnerability in Log4j, which is included in groov View, could be exploited by an attacker to remotely execute code on the target system running groov View. This vulnerability is identified in the National Vulnerability Database as: CVE-2021-44228.
Opto 22 has resolved this issue. Apply the updates to the above listed products immediately, regardless of whether you're using groov View or not.
