KB90092
Published: February 1, 2022
May not be able to set breakpoints in OptoScript block after certain comments
- PAC Control Basic
- PAC Control Professional
R9.6e to R10.4a (may occur in earlier versions)
R10.4b
In PAC Control Debug mode, if a comment in an OptoScript block meets the following criteria, you won’t be able to set a breakpoint after the comment:
- Be a single line comment (denoted by
//), not a block comment.
- Be on the same line as an instruction, following the instruction.
- The text of the comment contains at least one forward slash followed by an asterisk and without a space in between (
/*), which is the token denoting the start of a comment block.
- The text of the comment does not contain an asterisk followed by a forward slash and without a space in between (
*/), which is the token denoting the end of a comment block.
Do not use a /* (without a space in between) in the text of the OptoScript comment, or put a space between the forward slash and the asterisk.
