KB90171
Published: July 28, 2023
Clicking on gadget with broken connection to tag shows blank properties editor
  • GRV-EPIC-PR1, GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
GRV-EPIC-PR1, GRV-EPIC-PR2: all versions prior to 3.5.0
All other products: R4.2a to 4.4c
GRV-EPIC-PR1, GRV-EPIC-PR2: 3.5.0
All other products: R4.5a
In Build mode, clicking on a gadget with a broken tag connection (for example, the gadget is gray and has a NO ENTRY symbol over it) leaves the gadget properties panel on the right side of the editor empty. If you look in the logs, you may see an entry that reads:
GadgetPropertiesDisplay.displayGadgets() - An exception occurred while setting up editors: java.lang.IllegalStateException: Data type is NONE, this shouldn't happen.
Delete and recreate the gadget.
