KB90182
Published: July 28, 2023
Configure Dynamic Tags button may not work after adding OPC UA device
groov View on the following:
- GRV-EPIC-PR1, GRV-EPIC-PR2
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1, GRV-EPIC-PR2: 3.1.0 to 3.4.5
- All others: R4.3a to 4.4c (may affect earlier versions)
- GRV-EPIC-PR1, GRV-EPIC-PR2: 3.5.0
- All others: 4.5a
In Build mode, if you click the Configure Dynamic Tags button (in the Configure Devices and Tags dialog box) immediately after adding an OPC UA device to your project, groov View may not display the Configure Dynamic Tags.
Close the Configure Devices and Tags dialog, then re-open it.
