KB90196
Published: April 21, 2022
Digital output channel turns off or toggles after downloading and running PAC Control strategy
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
For groov EPICs: All versions prior to 3.3.3
For groov RIOs: 3.0.0 to 3.3.0
For groov EPICs: 3.3.3
For groov RIOs: 3.3.1
You may observe the following when you download a strategy to a SNAP PAC controller or groov EPIC processor that configures a mechanical relay digital output channel (channels 8 or 9) or a digital output channel (any channels 0–7) on any groov RIO listed above or a GRV-MM1001-10 module, and that channel was ON before you download and ran the strategy:
- A mechanical relay digital output channel (channel 8 or 9) turns OFF.
- In PAC Control Debug mode, the I/O Unit Channels Status window may display the channel as OFF while the Channel Status window displays the channel as ON; however, the channel is actually OFF.
- In the groov Manage module page, the mechanical relay output channel may display OFF while the channel page displays ON; however, the channel is actually OFF.
- A digital output channel (any channel 0–7) turns OFF then quickly turns ON.
