KB90199
Published: March 21, 2022
Extra blank lines added after line comments in OptoScript blocks
- PAC Control Basic
- PAC Control Professional
R10.4b to current
In PAC Control, if you change the name of a variable through the strategy tree and then edit an OptoScript block that contains that variable, after closing the block, PAC Control adds extra blank lines after each line comment in all OptoScript blocks containing that variable.
