KB90290
Published: August 17, 2023
groov RIO, groov analog, and some groov digital modules are unresponsive; groov I/O module LEDs are red
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
For groov EPICs: all versions prior to 3.4.0
For groov RIOs: all versions prior to 3.5.0
For groov EPICs: 3.4.0
For groov RIOs: 3.5.0
For groov EPICs, if all the analog modules and the following digital modules on the chassis are unresponsive and show red on the module LED, you may have this issue:
- GRV-IAC-24
- GRV-IACI-12
- GRV-IACDCTTL-24
- GRV-IACHV-24
- GRV-IACIHV-12
- GRV-IDC-24
- GRV-IDCI-12
- GRV-IDCIFQ-12
- GRV-IDCSW-12
- GRV-OAC-12
- GRV-OACI-12
- GRV-ODCI-12
- GRV-ODCSRC-24
- GRV-OMRIS-8
This issue is more likely to happen after the following:
- A module firmware update
- Hot swapping a module
- Other unexpected event that causes a module to go offline
For
groov RIO modules, the I/O may be unresponsive. This situation is more likely to occur after a firmware update or after starting the module.
Cycle power to your groov EPIC processor or groov RIO module.
