KB90307
Published: May 31, 2022
GRV-IVAPM-3 not always recognized after hot swap
Firmware for GRV-IVAPM-3
R1.3b
R1.3c
When you install or hot-swap a module onto the chassis, the module LED should turn red, blink off for less than one second, turn red, then turn aqua. With this issue, the module LED on a GRV-IVAPM-3 module may remain red or continue blinking red.
Hot-swap the module again.
