KB90324
Published: June 11, 2025
In groov Manage, the Autorun slider may not stay enabled
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
3.4.0 to 3.6.1
4.0.0
In the PAC Controller page of groov Manage, when you click the Autorun slider, it may not stay enabled if the strategy in permanent storage does not match the strategy that is currently in memory. groov Manage should display a message to inform you of the mismatch before disabling the slider.
If you notice this behavior, check that the strategy saved in memory matches the strategy stored in permanent storage.
