KB90329
Published: July 13, 2022
SNMP traps continue to be sent after being disabled
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
3.4.0 to current
In groov Manage, if you disable SNMP (from the groov Manage I/O Services page, click SNMP > Disable), the groov EPIC processor or groov RIO module should stop sending SNMP traps. With this issue, it continues to send SNMP traps.
Write 0 to the Enable field of the OptoMMP memory map of each Event message to disable SNMP traps.
  • Event Message 0: 0xF120 0024
  • Event Message 1: 0xf120 00E4
  • Event Message 127: 0xF120 5F64
