KB90343
Published: July 14, 2022
OPC UA clients cannot read/write tags when using system administrator account
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
For groov EPICs: 3.4.0
For groov RIOs: 3.4.0 to current
For groov EPICs: 3.4.1
If you are using a groov Manage administrator account as the username and password to authenticate to the native OPC UA server, your OPC UA client will not be able to read or write tags.
Create a non-administrative groov Manage account with appropriate read/write permissions and use this account as the username/password credentials.
