KB90375
Published: August 22, 2025
Some strategies upgraded from older versions may show inaccurate channel values in the Inspect I/O Unit Dialog
  • PACCONTROLPRO (PAC Control Professional)
  • PACCONTROLBAS (PAC Control Basic)
R10.4a to current
This issue impacts strategies created or saved in the following PAC Control versions:
  • R10.0
  • R10.1
  • R10.2
When running a strategy from an impacted PAC Control version in PAC Control R10.4a or higher, you may not receive accurate channel data in the Inspect I/O Unit dialog in Debug mode.
  1. Export the I/O and charts from the impacted strategy.
  2. In PAC Control R10.4b or higher, create a new strategy.
  3. Import the I/O units into the new strategy.
  4. Import any subroutines from the impacted strategy into the new strategy.
  5. Import all the charts individually (except the Powerup chart) to the new strategy using the option to create a new chart for each one.
  6. Import the Powerup chart to the new strategy using the option to update it as an existing chart.
  7. Inspect the I/O units in Debug mode to verify you are receiving accurate data.
