KB90399
Published: August 3, 2022
OPC UA tags with Number type are selectable in Build mode, but report type error in View mode
groov View running on the following groov EPICs:
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
For groov EPIC processors: 3.4.0 to 3.4.1
For all other part numbers: 4.4a
For groov EPIC processors: 3.4.2
For all other part numbers: 4.4b
In groov View, after successfully assigning an OPC UA tag of type Number to a gadget in Build mode, when you switch to View mode, that gadget displays a yellow triangle. When you click on the yellow triangle, groov View displays a message similar to the following:
The gadget's tag is a different data type than what the server or device provided.
Details: The string is configured as a FLOAT64, but the type returned from the server is class java.lang.Integer.
