KB90407
Published: July 6, 2023
PAC Control strategy overwrites existing setting for simple moving average (SMA)
Firmware for:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
All versions
If you set simple moving average (SMA) for analog inputs through groov Manage, and then you start a PAC Control strategy, the I/O is initialized and the SMA value is set to the default of 4.
Leave block 0 of the Powerup chart empty and use the Write Number to I/O Unit Memory Map instruction in the first block after block 0 to set the desired SMA value.
