KB90439
Published: July 28, 2023
Change to "No Tag" not applied to gadgets, events, or computed tags
  • GRV-EPIC-PR1, GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 3.4.0 to 3.4.5
  • All others: R4.4a to 4.4c
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 3.5.0
  • All others: R4.5a
If you choose "No Tag" in either of the following situations, groov View should display a message indicating that "No Tag" was selected and then make the change:
  • Change tags assigned to a gadget.
  • Select a tag for events or computed tags.
However, with this issue, groov View does not display this message nor does it make the change or apply the selection.
