KB90448
Published: July 28, 2023
Previously selectable CODESYS OPC UA tags now show as unsupported in the tag browser
  • GRV-EPIC-PR1, GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 3.4.0 to 3.4.5
  • All others: R4.4a to 4.4c
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 3.5.0
  • All others: R4.5a
Some CODESYS OPC UA tags that were selectable in previous releases can no longer be selected. In the tag browser, the data type of the affected tags says "Unsupported".
Configure the tag as a Dynamic Tag; for instructions, see the groov View User's Guide (form 2027), specifically Chapter 2, Building a Project > Working With a Device > Adding a OPC-UA Server > Using Dynamic Tags. You may need to use a separate OPC UA browser to find the tag's node ID.
