KB90457
Published: October 24, 2025
Tags added to server through OptoBrowser Configurator not immediately available to client
OptoOPCServer
R10.4a to R10.5c (may affect previous versions)
R10.6a
When you add tags to OptoOPCServer through the OptoBrowser Configurator, the tags should be immediately available to the clients. With this issue, the tags are available only if you restart the server.
After adding a tag through the OptoBrowser Configurator, restart OptoOPCServer.
