KB90490
Published: August 17, 2023
Sparkplug tags don't stale immediately after disabling Data Service
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
For groov EPICs: 3.4.0 to 3.4.5
For groov RIOs: 3.4.0 to 3.4.1
For groov EPICs and groov RIOs: 3.5.0
If you are running an MQTT Sparkplug device on your groov EPIC or groov RIO, when you disable the Data Service, a death certificate should be issued and the tags should be marked as stale/bad quality. In rare cases, the death certificate may not be issued and the tags may not be marked as stale/bad quality.
