KB90515
Published: May 22, 2024
CODESYS: Only first GRV-MM1001-10 module on chassis reports correct values
Opto 22 Library Package for CODESYS Development System
3.0.0.0 to 3.1.0.0
3.1.1.0
If you have multiple GRV-MM1001-10 modules mounted on your chassis, then in your CODESYS application, only the first module will report correct values. The rest of the modules report incorrect values; for example, if a channel is configured as an analog input, then the channel reports NaN.
