KB90516
Published: May 22, 2024
CODESYS: GRV-MM1001-10 modules may report false errors if no module in slot 0
Opto 22 Library Package for CODESYS Development System
2.0.4.0 to 3.1.0.0
3.1.1.0
If you have one or more GRV-MM1001-10 modules on your chassis and no module in slot 0, then in your CODESYS project, the GRV-MM1001-10 modules report the message "A module reports an error" and the diagnostic message reports "Module is missing."
If possible, insert a module into slot 0.
