KB90531
Published: July 28, 2023
"between" conditional format rule doesn't work if larger value in left field
  • GRV-EPIC-PR1, GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 2.0.0 to 3.4.5
  • All others: R4.2a to 4.4c
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 3.5.0
  • All others: R4.5a
If you configured a gadget with a "between" conditional format rule and you placed the the larger of the two values on the left side of the editor input (as in the following example), the condition will not work:
Swap the left and right numbers.
