KB90538
Published: May 23, 2023
PAC Manager: On Generic Read/Write page, error when using write-only address or navigating with Tab key
All versions prior to R10.5a
R10.5b
You may observe the following behaviors while working in the Generic Read/Write page of the Inspect Opto 22 Device window of PAC Manager:
- Enter an address for a write-only area in the Address field, then click Refresh. The Status field turns red and displays the message "Error reading area: The I/O Unit does not support this area."
- If you use the Tab key to move among the fields and then press Enter, sometimes PAC Manager displays a message similar to: "Enter valid scaling values."
Do the following:
- Close the main Inspect Opto 22 Device window.
- Click Tools > Inspect.
- Click Other > Generic Read/Write.
- Do the following steps; however, do not use the Enter key, do not click Refresh, and do not navigate through the fields with the Tab key. Use your mouse to select each field:
- Click in the Address field, then type or paste the appropriate address.
- Click in the Type field, then select the appropriate data type.
- Click in the Length field, then type in the appropriate length or use the up/down arrows to choose the appropriate length.
- In the Value column, click in the first value field, then type in the appropriate value. Do not press the Enter or Tab keys.
- If there are additional Value fields, click in the next field and type in the value. Repeat until all values have been typed in.
- Click Apply.
