KB90605
Published: August 17, 2023
API communication failures after upgrading to groov EPIC firmware version 3.5.0
Firmware for the following groov EPICs:
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-I1VAPM-3
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
For groov EPICs and groov RIOs: 3.5.0 or higher
NOTE: This KB article is for informational purposes. This issue is not a defect in groov EPIC firmware.
If, after applying version 3.5.0 or higher of groov EPIC firmware, your application's API calls to groov Manage, groov View, or Node-RED begin to fail, your application may be: running versions 1.0 or 1.1 of TLS, which are unsupported.
Update your application to use version 1.2 of TLS.
