KB90607
Published:
Cannot disable SNMP port on SNAP-B3000-ENET
Firmware for SNAP-B3000-ENET
R7.1i (may affect earlier versions)
Note: This KB is for information only. This product is obsolete; new firmware will not be released.
Disabling the SNMP port on a SNAP-B3000-ENET by setting the port to 0 doesn’t work; the port returns to 161 after reboot.
- Inspect the brain with PAC Manager.
- Navigate to Communications > SNMP.
- Set Community 0 - Read to "No." Do the same for all other "Community" entries.
- Set Community 0 - Write to "No." Do the same for all other "Community" entries.
- Navigate to the Status Write page.
- Select "Store configuration to flash."
- Click Send Command.
- Select "Restart Device from powerup."
