KB90610
Published: February 17, 2025
The “Subtype / Feature” column in PAC Control may display incorrect channel information for groov modules after changing the module type
PAC Control Professional
PAC Control Basic
R10.0a to current
After changing the type of a configured groov module in PAC Control Configure mode (for example, when you added a GRV-ODCI-12 module, clicked the checkbox to auto-add the channels, and then changed the module type to GRV-ODCIS-12), you may encounter any of the following:
- The Subtype / Feature column of the Configure I/O Modules and Points window displays the incorrect channel type values of one or more channels
- One or more channels is incorrectly configured
- A “type mismatch” error is posted to the controller’s message queue after downloading the strategy to the controller
Manually edit the affected channels and save your changes.
