KB90620
Published: August 20, 2024
If PAC Control strategy contains HTTP Get/Post commands with SSL, over time, PAC controller/control engine may become unresponsive
- GRV-EPIC-PR1
- GRV-EPIC-PR2
Firmware for the following SNAP PACs:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
Firmware for SoftPAC
For groov EPICs: All versions prior to 3.5.0
For SNAP PACs: All versions prior to R10.5g
For SoftPAC: All versions
For groov EPICs: 3.5.0
For SNAP PACs: R10.5g
If your PAC Control strategy contains HTTP Get or HTTP Post commands with SSL as the security mode, then over time, you may observe the following:
- For groov EPICs, various groov Manage services (including the PAC Controller) restart.
- For SNAP PACs and SoftPAC, control engine errors or failures.
The symptoms appear with a frequency corresponding to the frequency of the HTTP Get and HTTP Post commands: the more frequently the commands are called, the more frequently the symptoms appear.
