KB90683
Published: December 11, 2024
Offset and gain values that are out of range are not clamped
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
All versions
For channels that support analog inputs, when you specify values for gain and offset, if the values exceed the supported range, they are not clamped at the listed maximum/minimum values.
Validate the values before specifying them:
  • In groov Manage, the supported range of values is listed underneath the Offset and Gain fields in the channel's configuration page.
  • Review the OptoMMP Protocol Guide (form 1465) for instructions on configuring the offset and gain on analog input channels through the memory map.
