KB90752
Published: April 29, 2026
Inductive Automation’s Ignition may stop updating data on groov EPIC processors and groov RIO modules
Firmware for the following groov devices running Ignition 8.1.10 to 8.1.21:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
- GRV-R7-MM2001-10
- groov EPIC firmware: 3.3.0 to 3.6.0
- groov RIO firmware: 3.3.0 to 3.6.1
- groov EPIC firmware: 4.0.0
- groov RIO firmware: 4.0.0
On rare occasions, Inductive Automation®’s Ignition® Gateway may stop updating data on a groov EPIC processor or a groov RIO module running Ignition versions 8.1.10 to 8.1.21. Additionally, the Ignition log files may contain repetitive entries similar to:
INFO | jvm 1 | 2022/11/28 18:25:00 | at
java.base/java.util.concurrent.!LinkedBlockingQueue.dequeue(Unknown Source)
Restart the Ignition Gateway. For instructions, see the Ignition User Manual.
