KB90760
Published: May 22, 2024
Errors when attempting to select CODESYS string variables in groov View tag browser
groov View running on:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
- GROOV-SVR-WIN
- GROOV-SVR-WIN-BASE
- GROOV-SVR-WIN-SNAP
GRV-EPIC-PR1, GRV-EPIC-PR2: R3.5.0 to 3.5.1
All others: groov View R4.5a to R4.5b
GRV-EPIC-PR1, GRV-EPIC-PR2: R3.6.0
All others: groov View R4.5c
When attempting to select a string variable tag on a CODESYS® OPC UA server in the groov View tag browser, you may not be able to select it and may receive log error messages like the following:
OpcUaTagNode::handleSelection - An error occurred while persisting OPC-UA node s=|var|Opto22-Cortex-Linux.Application.PV.STRINGT;nsu=CODESYSSPV3/3S/IecVarAccess!
OpcUaTagNode::handleSelection - Internal server error.
Connect to the desired tag by defining a static tag in groov View. For more information, review the groov View User’s Guide (form 2027).
You can also use the WSTRING data type if your CODESYS project allows for it. For more information, visit CODESYS Online Help.
