KB90793
Published: March 2, 2026
Ignition gateway is restarted when it's already running
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIO: GRV-R7-MM2001-10
3.6.0 (may affect earlier versions) to 4.0.3
4.1.0
You may observe either of the following symptoms:
- On the groov Manage Ignition page, if your selected platform is already running (you can see Running in the Status section) and you click Save, the platform is restarted (the gateway is fully stopped and started again).
- While reviewing historian data, you may notice data missing during the time that the Ignition gateway was stopped and restarted.
Prior to clicking Save, refresh the Ignition page to update the Status section. If Ignition is running, don't click Save.
