KB90805
Published: May 22, 2024
Changing the Page menu display results in an empty page when viewed on the EPIC touchscreen or external HDMI monitor
groov View running on:
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
3.5.1
3.6.0
When choosing to display the Page menu as a folder tree in the Project Settings panel in groov View Build mode, you may encounter an empty page when viewing the project on the groov EPIC touchscreen or external HDMI monitor. You can only return to groov Manage.
Display the Page menu as a flat list instead of a folder tree:
  1. In Build mode, click Configure > Project.
  2. In the View Mode section, locate the Page Menu option and select Show as a flat list of pages.
  3. Click Save Settings at the top of the Project Settings panel.
