KB90856
Published: May 22, 2024
Database error when modifying a user in groov View Build mode
groov View running on:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
3.5.0 to 3.5.1
3.6.0
When attempting to modify an existing user in groov View Build mode, you may encounter the following error message: “Error: There was a database error when updating the user.” Your changes are not applied.
When editing a user, assign a default page to that user to successfully apply your changes. Once those changes are applied, edit the user again to reset the default page as needed.
