KB90928
Published: June 11, 2025
CODESYS: OPC UA client runs for only 30 minutes
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
For groov EPICs: 3.3.0 to 3.6.0
For groov RIOs: 3.3.0 to 3.6.0
For groov EPICs: 4.0.0
For groov RIOs: 3.6.1
The CODESYS OPC UA client runs for only 30 minutes. If you applied a valid CODESYS license (GROOV-LIC-CRE for groov EPICs, GROOV-LIC-CRE-RIO for groov RIOs), it should run without stopping.
Do one of the following:
  • Disable and re-enable the CODESYS runtime every 30 minutes.
  • Purchase and install a separate runtime license from CODESYS to permanently enable the OPC UA client.
