KB90966
Published: June 3, 2026
Revision: 4.0
If chart calls subroutine multiple times with NULL pointer as a parameter, controller may reset
- GRV-EPIC-PR1
- GRV-EPIC-PR2
Firmware for the following SNAP PACs:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1 (GEN2), SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
- SoftPAC
For groov EPICs: All versions prior to 4.0.0
For SNAP PACs: All versions prior to R10.7a
For groov EPICs: 4.0.0
For SNAP PACs: R10.7a
If a chart calls a subroutine multiple times with a NULL pointer as a parameter, the controller may reset.
Before calling a subroutine with a pointer as a parameter, verify that the pointer is not NULL using one of the following commands:
- Pointer Equal to Null?
- Pointer Table Element Equal to Null?
