KB91023
Published: November 25, 2025
Quality code flickers between good and bad
Firmware for the GRV-IAMI-8 module
All versions prior to 1.3g
1.3g
When you configure a channel on a GRV-IMAI-8 module to 4 to 20 mA and the field wires are not connected to the channel, the quality alternates between good and bad.
For example, if you are monitoring this channel in PAC Control Debug mode, you may see the quality code flicker between green (good) and red (bad).
