KB91088
Published: December 24, 2024
Channel 7 value of some GRV-IRTD-8 modules may read high
Firmware for GRV-IRTD-8 module
Units with serial number 921773 to 975855 or date codes from 10-9-23 (October 9, 2023) to 12-2-24 (December 2, 2024) may be affected.
Channel 7 of an affected GRV-IRTD-8 module reads approximately 3 degrees Celsius higher than the actual value.
In groov Manage, configure channel 7 of the affected module with an Offset of -3.2. There is no need to change the Gain.
Opto 22 has resolved this issue. If you have an affected unit, please contact the Product Support Group by emailing support@opto22.com.
